Label a Door Panel in a curtain wall
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2019-10-17 06:20 AM - last edited on ‎2023-05-17 03:44 PM by Gordana Radonic
‎2019-10-17
06:20 AM
I have a customised door panel part of a curtain wall. I want to label the door only but I can't.
Is there a way to just label the door?
Thank you
Solved! Go to Solution.
Labels:
- Labels:
Construction
Labels
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-10-20 08:51 AM
‎2019-10-20
08:51 AM
I don't know if this worked in AC18/19, but it definitely works now: with the Label tool active, hover you cursor over the Door Panel you want to label, then press the TAB key to cycle through available items to Label (whole Curtain Wall, Door Panel), then click to label when the Door Panel is highlighted with the pre-selection highlight. The Info Tag will also tell you what you are about to label.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-10-20
08:51 AM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-10-20 01:04 PM
‎2019-10-20
01:04 PM
I am on AC 20 and it works as you said. Thanks for the hints
