2022-07-29 03:19 AM - last edited on 2022-09-28 03:01 PM by Oleksandra Vakariuk
I was wondering if anyone knows of a label tool or object that can create an arrow on both sides of an assembly like in the below photo?
2022-07-29 05:07 AM
In my short opinion, I don't think so.
I haven't seen gdl support for leaders yet.
So, how about solving the line below with a line.....
2022-07-29 05:43 AM
@RileyDA Have you considered a dimension with multiline text? Dimensions can be used for more than dimensions. Obviously this wouldn’t work if you are pulling label data from the entity.
2022-07-29 05:44 AM
You can't have custom arrow heads on a leader (it is all hard coded in the software).
You can however, get all of the co-ordinates and angles of the leader line in a label object (not the autotext object as that is not a scripted object), so I guess you could script the second arrow head in - but you will need to know what you are doing in GDL, and as I said, you will not be able to use the autotext label.
It will have to be a specifically scripted label that allows you to add your own text.
I haven't seen this done though so I am not 100% sure it could be done.
Or maybe just create an object with stretchy hotspots for the leader line (again you need to know a bit of GDL) and use that with your text - of course they won't be linked together unless you group them.
2022-07-29 10:34 AM
This is probably as close as you can get with a dimension. Note the arrows will be placed inside or outside depending on whether they fit.
2022-07-29 04:22 PM
How did you do this?
Did you write a new label gdl?
2022-07-29 07:12 PM
It is a basic linear dimension. If you drag the text of the dimension away from its default position it will create a leader. You can adjust the position of the leader and use multiline text to place it as shown.
2022-07-29 11:37 PM
That is what I call thinking outside the box with your Archicad tools. 🙂
