‎2006-07-18
05:27 PM
‎2023-05-30
10:08 AM
Rubia Torres
‎2006-07-18 07:32 PM
‎2006-07-18 08:10 PM
‎2006-07-18 08:17 PM
TrvlDeWrld wrote:If you look in the Navigator, under "View Map", you can change which layer combination is assigned to a View. I think you can get the same thing by right-clicking on the view on the layout and selecting "View Settings"
Thank you for your help. Though, I am not sure where to access that setting. I have found the layer manager for model and for layout book where do I find the one for the view?
‎2006-07-18 08:47 PM
‎2006-08-22 04:02 PM
TomWaltz wrote:Is there a way to control the layers of a drawing placed on a layout without having to have layer combinations set up. I used to do it in v9 but cannot seem to be able to do it in v10.
...If you look in the Navigator, under "View Map", you can change which layer combination is assigned to a View. I think you can get the same thing by right-clicking on the view on the layout and selecting "View Settings"
‎2006-08-22 06:51 PM
Haneef wrote:NOPE. That ability went away in AC10.TomWaltz wrote:Is there a way to control the layers of a drawing placed on a layout without having to have layer combinations set up. I used to do it in v9 but cannot seem to be able to do it in v10.
An example of where I require this is for key plans, where I've created the different highlighted areas on different layers (eg. Block A, Block B) which I then used to control on the layout. I'm hoping that I dont have to have a lot of layer combinations set up.
Thanks
Haneef
‎2006-08-24 06:15 PM
TomWaltz wrote:I can only describe this as a GREAT TRAGEDY!Haneef wrote:NOPE. That ability went away in AC10.
