Layout Automatic numbering with automatic revision added.
In AC21 a revision number would automatically be added to my drawing number which would prevent the overwriting of previous revisions and allow me to retain a comprehensive set of all revisions issued. Since upgrading to AC22 I have been unable to enable this feature. Where do I find this setting and how do I re-activate this useful feature?
Example:
Layout number A01.1 would become A01.1.01 for rev 01 and A01.1.02 for rev 02
6 REPLIES 6
Could you post 2 screenshots?
One about the Layout Settings Dialog in AC21, the other the Layout Settings Dialog in AC22?
Eli Chiasson
This isn't in Subset or Layout Settings, but if you have #LayID.#RevID on your titleblock it will achieve the same thing.
Then set your Publisher up with a Custom file name: <SourceID>.<CURRENTREVISIONID> <SourceItemName>
Maybe that was set up in your AC21 template?
Eli Chiasson
Dexel Architecture
http://www.dexel.ca
AC19-23 USA+MEP • i7-7700 3.6GHz | 32GB RAM • Windows 10 Professional
Thank you very much, you hit the nail on the head. I have been trying to resolve this for 6 months now. With this renumbering your previous revisions are not overwritten. Simple but impossible for me to find & I have been using Archicad since version 3.
Eli Chiasson
Great, glad I could help.
Eli Chiasson
Dexel Architecture
http://www.dexel.ca
Hi Eli, can you explain how to:
I'm on AC22 and can't seem to follow your instructions. Thank you!
Found it! cheers
FYI in publisher book, right click the folder, then go to Rename Items
https://helpcenter.graphisoft.com/user-guide/77114/
