Layout Book (Scale) /Floor Plan (Exit Sign)
Hi Everyone,
I wanted to see if anyone knew a quick fix for these two items below. I am using ArchiCAD 19.
1)Power/Data plans
I wasn't able to fix the exit sign arrow issue (image attached). I am being asked to change the arrows to point towards the door.
2) Wall/Detail Section:
I wasn't able to fix the scale issue (image attached). I change the scale to 1 1/2" = 1'-0" but then the drawing becomes too big and goes off the page. Then when I scale it back to a normal size it doesn't keep the scale size and reverts to a smaller scale.
Thanks
2nd image for 2nd issue posted above. I am using ArchiCAD 19.
ā–ŖWall/Detail Section:
Thanks,
David Maudlin
Your screen shot shows that the Wall Section's original scale is 1/4"=1'-0". Drawings should be created at their output scale so text and other non-model elements size correctly. If the Wall Section is to be output at 1 1/2"=1'-0" scale, then go back to the original Wall Section, change its scale to 1 1/2"=1'-0" and adjust the text elements.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
