ā2014-07-14
03:23 PM
ā2023-05-26
02:27 AM
Gordana Radonic
ā2015-06-10 01:11 PM
ā2016-04-19 06:46 AM
ā2016-08-29 08:14 AM
artisttheking wrote:similar problem exist. I would say that is not really an easy talk but a defect. I can write a separate bug report if it should be tracked separately. I'm so tired of annoying and illogical bugs.
I can confirm this bug with autotext in AC-18.
This is extremely annoying since it basically makes automatic spreading of schedules on multiple layouts function half-useless.
For example:
We need to publish door and window schedules. Each sheet should have its own unique ID printed out. But now the LayID autotext will display the range of layout ID's and not the unique ID of the current layout.
To make matters worse, we can't even correct this manually since we are dealing with the multi-sheet layouts.
In older archicads (tested on AC13) this autotext functionality worked correctly.
