2007-02-02 06:25 PM - last edited on 2023-05-19 10:22 PM by Gordana Radonic
2007-02-02 06:26 PM
2007-02-02 08:46 PM
sweeper71 wrote:Set to print in color and change the pen set of the drawing to produce the results you want. I have recommended against "All colors to black" for years since it is very limiting compared to using pen sets, and not really that much easier.
They are all solid dark black (I am choosing to plot with no color, I change it to black an white in my plot settings). This doesn't help me when I need to create a drawing that reads easily. Does anyone know how to fix this problem?
Another one I have run into is when I use the fill tool, especially the 25% fill the background comes out solid black. So you can't see anything but a black box. I fixed the background to be transparent but it still comes out black. Is there something i'm missing?If it is the old (pre-AC10) 25% fill the problem is that it is a vector fill consisting of a pattern of dots. If the dot spacing is not more than the size or the pen then it will print solid black.
2007-02-05 04:06 PM
