ivorhession
Lines between walls on different Renovation Status
Hey All,
I'm having an issue with walls on different reno status.
On the image attached the wall going north south is on demolitions, and the wall going East West is on existing.
Is there a good way / correct way to suppress the line between the two walls?
(i can bodge it by running the north south wall into the existing wall by a a few mm with the end line turned off, but its not very satisfactory to do that everywhere this happens.)
That's in advance
Ivor
Ivor Hession
Principal
tóg_architecture
www.togatchitecture.com
AC28 Solo / Windows 11 / PC / AMD Ryzen 5 / 36 gb ram / Gigabit RTX 3040 /
1 Solution
Eduardo Rolon
In the Renovation Palette uncheck the "do not intersect"
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Go to post
2 Replies 2
Eduardo Rolon
AC29 US/INT -> AC08
ivorhession
Yes, that has done it, i knew i was missing something simple.
Thanks so much.
Ivor Hession
Principal
tóg_architecture
