Linking an Excel file
Gisele
Can I link an excel file to AC, without losing the formatting?
Is it possible to make an excel file automatically update in AC (after I edit it in Excel)?
AC 26 - 5002 USA FULL
Win11 Pro 22H2 - 13th Gen Intel(R) Core(TM) i9-13900KF 3.00 GHz - 64 GB - 64-bit operating system, x64-based processor
scottjm
You can’t link an excel file directly unfortunately. I would love that feature though.
The easiest way is to print your excel content to a pdf and place that as a linked drawing in archicad, with auto update set.
That way when you change your excel content and re-print to the pdf and save it over the top of your previous pdf, the updates will come through to archicad automatically.
scottjm
Thank you!
