SOLVED!
MEP Modeler, Cannot Access Properties?
Andre_Steynberg
Hi all
So quite a few improvements in the MEP Tool lately which are much appreciated.
My question though, can we not access any Properties in a MEP route anymore?
I have built in specs in my MEP objects' Properties which I cannot seem to label anymore, the info is there in the MEP objects but I cannot label it?
Is there a work around or a specific label I should be using?
Operating system used: Windows 10
Andre Steynberg
Win 10 64-bit
AC27
1 ACCEPTED SOLUTION
Solution
The MEP objects in 27 currently can no be labelled.
https://community.graphisoft.com/t5/Modeling/MEP-multi-mistake/m-p/400451/highlight/true#M168678
I am not sure if the most recent update (5003) fixed that.
There were some MEP improvements, but I don't think labelling was one of them.
3 REPLIES 3
Solution
Thanks Barry, yea you are right, thank you for confirming.
It hamstrings my workflow but we'll find a way around for now, hoipefully GS brings it back soon.
Just boggles my mind that this functionality would be taken away in the first place
Andre Steynberg
Win 10 64-bit
AC27
Lchacon
Hi Andre, I'm actually having the same issue. I was wondering if you could share how you managed to solve this situation.
Setup info provided by author
