MODULES AND RENOVATION FILTERS
I've been working on a renovation project. I'm using MODULES and have had issues on showing te modules with RENOVATION FILTERS. The modules do not appears on saved views! Does somebody is facing the same issue?
1 Reply 1
schagemann
Have you checked that the saved view is either using the correct layer combination and / or includes the place hotlink modules master layer - note you typically define the master layer when you first place a module.
VKTRS | macinteract
Design Technology Managers - all on macOS | since AC 6
Archicad Framework > Smart Template 28
Smart Tree, Transmittal and Universal Label plus other smart GDL Objects
