MULTI LINE DIMENSION TEXT
IS THERE ANY WAY TO MAKE THE "CUSTOM TEXT" OF DIMENSION STRINGS INTO MULTI-LINE TEXT? CURRENTLY I ADD A TEXT BOX BUT THE TEXT BOX DOES NOT ADJUST POSITION WITH RESPECT TO THE DIMENSION STRING AS THE DOCUMENTS DEVELOP OVER TIME... THANK YOU.
Hi johnneebee
I've try the same but has no luck. We end up has to use text block.
But if anyone know a way please share, it will be great if Graphisoft can make it happend
There is no multi-line dimension text.
Make a wish (I am sure there is one there already) and you never know it might appear in a future version.
A new feature in ARCHICAD 19 is that any Dimension Text can be multi-line.
