MULTI LINE DIMENSION TEXT
IS THERE ANY WAY TO MAKE THE "CUSTOM TEXT" OF DIMENSION STRINGS INTO MULTI-LINE TEXT? CURRENTLY I ADD A TEXT BOX BUT THE TEXT BOX DOES NOT ADJUST POSITION WITH RESPECT TO THE DIMENSION STRING AS THE DOCUMENTS DEVELOP OVER TIME... THANK YOU.
3 Replies 3
Hi johnneebee
I've try the same but has no luck. We end up has to use text block.
But if anyone know a way please share, it will be great if Graphisoft can make it happend
There is no multi-line dimension text.
Make a wish (I am sure there is one there already) and you never know it might appear in a future version.
A new feature in ARCHICAD 19 is that any Dimension Text can be multi-line.
