2024-01-06
03:56 AM
2024-01-12
10:28 PM
Hi All. I have had to trim vertical timber plank elements to a 'complex' multi eave line building using an 'air' roof as the trim guide for the cladding. I want to get rid of the uncut/profile lines. Any thoughts would be welcome and is this possible in ArchiCad 21?
D.
2024-01-06 07:34 PM
If you are referring to the "air" roof lines the solution is to place them in a layer that will be off in all of your saved views. Usually name is X-SEO.
another Moderator
2024-01-08 09:18 AM
Many thanks Eduardo!!
