SOLVED!
Master Layouts - which layouts are they used on?
gedzior84
Hello.
Longstory short - I have maaaany layouts in my layout book, and maaaany master layouts as well.
I want to clean things up, and my question is:
Is there a way to know on which layout is a specific master layout used?
Whenever I want to delete a master, there is a pop-up saying, that this master is used somewhere, but I would like to know where exactly.
Thank you in advance
1 ACCEPTED SOLUTION
Solution
David Maudlin
gedzior84:
At the top of the Navigator palette is a pop-up list, change its option to "Tree by Master".
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
3 REPLIES 3
Solution
David Maudlin
gedzior84:
David
gedzior84
Wow!
Everyday something new! I knew that this list was expandable, but I never checked these options.
Thank you very much!!! It helped me a lot!
As for my signature - I will surely do that!
It is also possible to create a Sheet Index, which can display the Master Layout the Layout is based on. You can even use the Master Layout in the generated schedule as Headline to group Layouts by Master Layout.
