Master layout templates in Archicad 11
This goes way back to Archicad 11 (Mac)I haven't used my version of Archicad 11 in several years. I have a project that I want to print/plot with a title block. The documentation for Archicad 11 says "ArchiCAD includes several Master Layout templates. You can use one of the predefined Master Layouts, or customize your own.". My question is, where can I find these Master Layout templates? When I go to layout book in the navigator I don't find them.
Thanks
5 REPLIES 5
vistasp
In the layout book, make sure you are listing by Subset and not by Master. HTH.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
Thank for the reply - I am however listing by Subset and not by Master. Any other thoughts? Is it possible that these templates just didn't load? Where can I find them?
Thanks
vistasp
That's odd. If there are masters, they should show up.
If you have another project with the masters showing correctly, you can import them.
= v i s t a s p =
bT Square Peg
Link
Please show us a screenshot! I have never seen this before.
Link.
David Maudlin
Try looking at Applications > Graphisoft > ArchiCAD 11 > Defaults > ArchiCAD > ArchiCAD 11 Template.tpl.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
