Gisele
Missing library elements
What is the best way to recover the missing doors?
AC 26 - 5002 USA FULL
Win11 Pro 22H2 - 13th Gen Intel(R) Core(TM) i9-13900KF 3.00 GHz - 64 GB - 64-bit operating system, x64-based processor
4 Solutions
Eduardo Rolon
By loading the Migration Libraries.
See:
https://help.graphisoft.com/AC/26/INT/index.htm?rhcsh=1&rhnewwnd=0&rhmapid=#t=_AC26_Help%2F010_Migra...
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Go to post
Eduardo Rolon
Need to read the link.
You need to add the Migration Libraries that are in the same folder that Library 26 is located.
AC29 US/INT -> AC08
another Moderator
Go to post
Eduardo Rolon
GO to File-> Library Manager
There use the ADD button to make sure you have that list of libraries loaded.
Once you hit reload there shouldn't be any errors
AC29 US/INT -> AC08
another Moderator
Go to post
Eduardo Rolon
Once you load the missing libraries AC will be able to read the missing elements.
That is provided that those parts are from the AC library that you have installed. If the Libraries are from another source (ie office) then you need for them to send you a copy.
Also if the project was started using AC_INT (or any other countries version) and you install AC_US or viceversa  then those Libraries will no have your missing objects and you will need a copy of those.
From your first screenshot you are missing a AC19 Door, loading Migration Libraries should have fix it. The other screenshot indicates that you are missing AC26 objects and loading the AC26 Library should fix it.
Those folders should be installed in "C:\Program Files\Graphisoft\Archicad 26"
AC29 US/INT -> AC08
another Moderator
Go to post
7 Replies 7
Eduardo Rolon
See:
AC29 US/INT -> AC08
another Moderator
Gisele
I have dragged and copied library 26.lcf to the library manager but the doors are still missing.
How can I check the library source for the missing doors?
Eduardo Rolon
AC29 US/INT -> AC08
another Moderator
Gisele
I have followed the instructions and clicked on the migrate button for each of the listed library in my project's library manager.
To make it more concrete, I will try to work on one element.
How can I reload the missing NCS Drawing Title 2 26.gsm?
Eduardo Rolon
AC29 US/INT -> AC08
another Moderator
Gisele
The on add button prompts me to add a file or folder that I am missing.
I am not sure how this helps me recover the missing elements.
Eduardo Rolon
AC29 US/INT -> AC08
another Moderator
