Missing windows
Aussie John
I am tearing my hair out here
A couple of window parts are refusing to show up in plotmaker.
Some points;
1) I am not on a network and all files/libraries are local
2) I have cleared all my caches
3) the windows show in the plotmaker elevations and other views generated in the CAD 3d
4) I reverted to a previous version of plotmaker/Archicad in deperation to no avail
Im resorting to creating a patch over the CAD plans.
Is this a bug or any clues what is going on?
thanks
Cheers John
[/size]
9 REPLIES 9
Are the drawings in PlotMaker linked directly from the PLN?
Perhaps BGArchiCAD has lost track of the library parts.
Aussie John
Hi Matthew- yes they are directly linked.
I also forgot to say that I created and imported a plotmaker file and the subborn windows were still missing.
It is odd that the 3d views generate the windows.
Cheers John
[/size]
You might want to check to see if there is a parameter to turn the window off in 2D views. Many window objects have this, and it might have gotten checked by mistake.
Richard
AC26 (since AC6.0), Win10
Aussie John
thanks Richard but that doesnt appear to be the solution
Cheers John
[/size]
__archiben
you haven't inadvertently saved your views with 'RCP' on in the display options have you . . . easily done.
~/archiben
b e n f r o s t
Aussie John
The thing is only a couple of window types are affected and doors are fine, which kinda suggests the problem might be with the window part
Cheers John
[/size]
Sounds like the only remaining possibility. Have you tried replacing them with a different window to test this?
Which library are they from? Are the walls they are in part of any SEOs?
Djordje
PlotMaker is creating separate layers for doors and windows; check their status.
Shooting in the dark ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Aussie John
Djordje wrote:
PlotMaker is creating separate layers for doors and windows; check their status..
Djordje, Many thanks- I forgot that plotmaker put windows and doors onto separate layers
Cheers John
[/size]
