Modules And ceiling height
Hello, I would like to create modules with walls who automatically make junction with the ceiling of the floor where they are. If I have multiples instances of the same module on different floors with different ceiling heights, I want the wall height to adjust by itself. Is it possible?
Tank you
1 REPLY 1
Lingwisyer
Hero
Do your ceilings all have the same offset from the floor above?
Use a multistory module. Set your wall top to the story above with the desired offset, then when you place your module, set it to adjust story height based on host.
Ling.
Win10 | R5 2600 | 16GB | GTX1660
