Finishes-Only option in Partial Strucure Display
hi all,
I am missing a Finishes Only option in Partial Strucure Display (3D). Is there workaround to get only finishes without core geometries? Beside the splitting of the composites into seperate e-g- walls?
Thank you for any hint
BR, Florian
AC24 4018 INT, Win10, Quadro P2000, Xeon, BIMCloud
7 REPLIES 7
Hello Florian Lohberger,
Did you use this tool ?
Or did you check these parameters into your composite wall ?
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
I think Florian is referring to hide the core and just show the finishes.
In this case, it is not possible.
But you can always create a wish.
Yes, I want to hide the core.
Thanks for the super fast reply!
I'll make a wish 😉
BR Florian
runxel
Hero
Just out of curiosity: Why do you need that? In what context is that necessary?
There is an existing wish about this I created a few years ago:
https://archicad-talk.graphisoft.com/viewtopic.php?f=25&t=49055
@runxel
for visual control about the work in progress.
This would be useful in case you have, for example, a extremely detailed structure/core model from the engineer that you don't want to be coincident with a simplistic core on Composites and CP's in a design phase. This often causes coincident surfaces flickering. With this option, we just hide the "designed core" and the detailed structure would appear.
