Newbie question: placing dimensions with a given step
Hello!
I'm a newbie, please help me with archicad. I have an irregular-shaped area. I need to place dimensions with a regular given step. I.e. i want to place horizontal dimensions on a regular vertical "grid"... I hope I asking well. Please ask additional questions if something is not clear..
Thanks in advance.
Milena.
5 Replies 5
You could place hotspots using the multiply command at your regular step locations and dimension to them.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 29-Latest USA
2024 M4 Max MacBook Pro-macOS 15.5 (128GB (16 Core CPU + 40 Core GPU)
Or, you could use the structural grid tool, with the option to automatically insert dimensions...
The Structural Grid has 'issues', but works for many situations ... see this thread:
http://archicad-talk.graphisoft.com/viewtopic.php?t=10220
Thank you very much!
Could you, please, write me step-by-step instructions? How to achieve this?
I attached a file with screenshot what I need...
Petros Ioannou
-place a hotspot on the lower point.
-Select the hotspot
-Edit ->Multiply->Drag/spread/spacing(define the distance)/OK
-click on the plan->move vertically and press shift->the hotspots are copied
-use them as reference points for the dimension tool (click on them) as Gerald suggested.
HTH
Petros
PS read the manual!!! (C:/ProgramFiles/Graphisoft/Archicad9/GraphisoftDocumentation)
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
TomWaltz
On using Multiply, see my attached PDF (from one of my seminars)
Tom Waltz
