Non-perpendicular structural grids "NOT" showing up in elev.
rob2218
So..I have these structural grids.
they are individual grids but that should NOT make a difference on how they show on elevation.
AS you can see from the diagram (with elevation in trace view) the structural grids that are "not" perpendicular DO NOT SHOW UP? what gives? I have the appropriate box, toggle, wizbang, radio button, and every button known to man checked off.....WHY ARE THE GRIDS "ALL" NOT SHOWING UP?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
4 REPLIES 4
Rob,
Where exactly do you want the non-perpendicular grids to show up on the elevation? How do you show and invisible plane at an angle to a view? I have never shown a grid that is not perpendicular to the view
Scott
rob2218
In AC18, I was able to "show" the column grids that were non-perpendicular on an elevation. Let me see if I can bring up that example.
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
i>u
Edgewater, FL!
SOFTWARE VERSION:
Rob,
My guess would be that the non-orthogonal grids would need to intersect with the elevation cut line and would be shown at this point
Scott
