Do you have the "Current Zoom" saved with your view settings for each view? Also make sure the "Ignore zoom..." box is un-checked.
Go to your Kitchen view, make sure you are zoomed to the correct location, in View Settings "Get Current Window's Settings", select the "Current View" zoom and un-check the Ignore zoom and rotation box.
Go to Bathroom view, if location is not correct zoom to the right place. Go through the same process with View Settings selecting "Current view" and un-check "ignore zoom" box.
Note that next time you go to the saved view "Current Zoom" will have changed to "Zoomed Area"
