2021-11-15 09:31 PM
I am trying to create some objects from some 3d files that I downloaded. Typically when I do this I can open the object created and then change the 2D Symbol to what I want to see in plan. This has always worked perfectly, but now when I try to do it, the object does not update. Instead, it always shows me the 2D View (I'm not sure what the difference of these is supposed to be), which I cannot modify at all. Is there a way to fix this?
Solved! Go to Solution.
2021-12-03 03:35 AM - edited 2021-12-03 03:36 AM
If you are putting the linework of your desired 2D symbol in the 2D Symbol tab of the object script, the 2D Script tab should be blank (or fully commented ( ! ) out).
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
2021-11-16 02:04 AM
Check the 2D Script? The 2D Symbol will get overridden by anything in the 2D Script, so check there and delete if required.
2021-12-02 09:06 PM
I am not really familiar with the process of scripting. Do you have a suggestion of what it should say?
2021-12-08 08:47 PM
Thank you! This worked great!
2023-02-14 09:53 AM
Can someone show me how this is done ( the script part)
I have always been able to put a fill in the 2d view, delete lines etc. but this doesn't seem to work in newer versions (26)??
2023-02-14 10:16 AM - edited 2023-02-14 10:17 AM
Ensure that your 2D Script is not trying to draw something / blank? As per the thread solution.
2023-02-14 10:28 AM
I have noticed now that you have to type a FRAGMENT2 1, 0 command in the 2D script.
Leaving it blank or commenting out all the lines does not seem to work any more.
I haven't really looked at it as I not using 26 yet.
Barry
2023-02-14 08:45 PM
Thanx, works great, didn't put anything in the script.
Just copied the object in plan view and pasted it in the 2D symbol window, edited like I used to in older versions and saved.
Only tone thing; after the operation AC behaved very strange for a minute, couldn't select or move anything, it's like AC needed a minute to figure out what I did
