Only FILL wants to move a little bit.
LeeJaeYoung
FILL and LABEL are together.
1. Only FILL wants to move a little bit.
What should I do?
2.Can I delete only FILL and not delete LABEL?
Should I disconnect with "Convert to independent label" and delete FILL?
Solved: Re: how do I disconnect the label? - Graphisoft Community
AC27 on window 11
Gerry Leonor
  1. are you sure that label is associated to the fill? if not, there's something going on with it. is that using the normal Text Label or a special kind of label? it's supposed to move with the fill. unless it's just a simple Text & not a Label.
  2. if the label is associated to the fill, then no -- you cannot delete the fill & still have the label. you can delete the label & still retain the fill, but not vice-versa.
AC25 | Win10 | 64 bit | 16Gb RAM |Intel i7 8700 @ 3.20Ghz
come join our unofficial Discord server
https://discord.gg/XGHjyvutt8
thank you ^^
AC27 on window 11
