LeeJaeYoung
Only FILL wants to move a little bit.
FILL and LABEL are together.
1. Only FILL wants to move a little bit.
What should I do?
2.Can I delete only FILL and not delete LABEL?
Should I disconnect with "Convert to independent label" and delete FILL?
Solved: Re: how do I disconnect the label? - Graphisoft Community
AC27 on window 11
2 Replies 2
Gerry Leonor
  1. are you sure that label is associated to the fill? if not, there's something going on with it. is that using the normal Text Label or a special kind of label? it's supposed to move with the fill. unless it's just a simple Text & not a Label.
  2. if the label is associated to the fill, then no -- you cannot delete the fill & still have the label. you can delete the label & still retain the fill, but not vice-versa.
https://discord.gg/XGHjyvutt8
LeeJaeYoung
thank you ^^
AC27 on window 11
