Organizing Details for Easy Retrieval?
I posted this awhile back on the old forum, but never got a really satisfying answer. Thought maybe some creative ideas might have come out at ACU West. So here's the issue:
Does anybody have a good system for keeping track of a library of standard construction details that you've drawn over time, so that you can sort through them quickly and pull out the appropriate ones for placing into Plotmaker? Obviously you could draw one detail per file, put a paper copy in a binder and find it that way. Or keep all your details in one large file, use one view set per detail and send a live copy or a PMK to Plotmaker. This is how I'm currently doing it, but there must be a better way.
I'm wondering if there is anything more efficient, like maybe having a slew of PMK's already pasted up on layout pages, and sorting and dragging around details from there. My only complaint with this is that if you have 10 eave details (labeled eave-1.pmk, eave-2.pmk, etc.), you don't get the automatic title block feature to work as well when you only need eave-5.pmk. Seems like everything I've come up with is pretty kludgy. Any good ideas?
Richard
AC26 (since AC6.0), Win10
23 Replies 23
Hi Eric,
You wrote
Eric wrote:
Some of our standard details are linked directly to the standard detail PLP file instead of placing them into the project file directly
Now the million dollar question is:
If I put a detail marker on my floor plan with a detail Reference ID and Drawing Number and Sheet Number set to PM, now when I import the building plan file and then the (standard) Detail plan file how do I combine or link a specific detail from detail plan to the blank detail marker coming from the view sets on my building plan?
Thanks,
Joseph Harouni
After much cogitating and experimentation based on the above, I've come up with a pretty good workflow for managing office details. In retrospect, it seems obvious, but since it wasn't to ME, I'll share it in case others may find it useful.
1) Put all office standard details in ONE file, per Eric's suggestion. Each detail needs its own VIEW, which includes scale and display zoom. I've found it works best for me to have each category of detail on a separate story (e.g. story 1 = standard Tee footings, story 2 = retaining walls, story 3 = drilled piers, story 4 = floor framing, etc.), and then put each detail on a single layer. (e.g. Footing 1 = layer 01, Footing 2 = layer 02.) An important timesaver is to make sure that the View Name works as the future title of the detail in Plotmaker.
2) Now it's easy to open Publisher and with the individual Views on the left, create a new View Set for the right pane (e.g. Smith Residence). Running down the details in the left pane, if you significantly enlarge the Navigator Preview window you can get a pretty good idea of what's in the detail, or just double click on the view to check it out more carefully. When you spot a detail you want to include, just drag it over to the "Smith Residence" view set. You also can organize the Smith Residence view set with major categories if you have too many details for a flat file structure.
3) Publish the Smith Residence view set as PMKs to the Smith job folder. (Publish with real folder structure if you've got a lot of details.) When you do this, each PMK will have the file name of the original view for that detail. (View Name.PMK)
4) Open Plotmaker and drag PMK's onto each layout sheet. If you've set up a master title type with Autotext which includes "drawing name", "drawing number", and "drawing scale", and set PM to automatically add this as a default title, each of the PMKs will come in uniformly titled, with label, number, and scale. (Note: This was not possible in the last version of PM because the .PMK file extension was not deleted in the autotext drawing name. Fortunately this bug was fixed.)
I think that PMKs are better than live PLNs, because a) they're faster to display, b) all the details can stay with the layout for archiving, and c) if you update your master detail file, it doesn't change everything in past projects.
So that's it. Not sure if this works exactly the same on Macs, but this seems to work for me on a PC. Hope that's helpful.
Richard
Richard what is the advantage of having one layer for each detail and ending up with 500 layers for 500 details vs. possibly one master layer of ArchiCad for all?
My question to you and Eric remains; how does one link these details in PM to the detail marker on the floor plan?
Thanks,
Joseph Harouni
Thanks,
Joseph Harouni
Joseph:
You only need enough layers to cover the number of details on ONE story (say, 50?) I put each detail on one layer so that it can be easily displayed by itself, and zoomed with "Fit in Window".
If you need a detail to link to a specific detail marker/detail window, then you'll probably need to publish that detail as a module file or a DWG, rather than a PMK, since these formats are needed to merge into a detail window. Having multiple stories creates complications with module files, so this may be more difficult with a single file detail PLN. If the detail windows would merge PMKs, it woiuld be terrific.
Richard
The concept of how a model is translated in 2d is GS’s duty. But GS never ever solved or attempted solving it and by now we know it will never be solved. Instead of using the computer GS invented an ill-conceived proprietary database manager.
Again the management of all the parts of the project has to happen in the finder and not somewhere else.
I have to be critical, because I have complained much about this aspect and now it hurts most of us.
To answer Joseph's question:
Of course a detail drawing cannot be linked to an external detail so that's why if you publish all of your details as modules you can then merge them into your project file and then link to them with a detail marker using the automatic detail numbering.
We use 2 types of "standard details":
1. Project specific details (apply only to the current project, not to all projects)
2. General details (apply to all projects)
General details are left linked to the external "standard details" PLP file and are placed in PM directly while the project specific details are merged into the project file as needed and referenced accordingly. This is where good Plotmaker templates really help you. If you setup sheets and notes for general details they can be left in place and you can reference them consistently from job to job.
Richard,
As I understand the name of the layers do not reflect the content of the detail itself; if so how can you view the detail you want base on layer naming of 01, 02,......49,50 for each detail?
Thanks,
Joseph
Joseph wrote:
Richard,
Thanks,
Joseph
First detail you draw on Layer 01 on a story with, say, eave details. Every other layer is turned off so you only see the first detail. Zoom to fit window and create a named View for that story and that custom layer set called whatever you want (e.g. Eave Detail with Gutter), then turn off layer 01 and turn on layer 02. Create a named View for that detail (e.g. Eave Detail - No gutter) Now you can view the details, either by highlighting the View Name in Navigator and looking at the Navigator Preview, or by Double-clicking the view name and actually looking at the individual details as they pop up.
The Navigator will show every story with the named category of details (if you've named the story), with the individual names of details a level down in the hierarchy.
Hope that's clear.
Richard
Thanks Richard, finally I think got it.
By the way if one creates a layer combination, let say 01 with layer 01 on only, then you can use the fly out button in the navigator to turn on the specific detail on in the floor plan also.
Thanks for all the help.
Joseph Harouni
Hi Eric,
Linking to the markers is important to me, so I want to check to see if I'm understanding your suggestion: for X number of external details, do you then repeat X times: create detail window, merge (or hotlink) appropriate detail? Seems like a pretty tedious process if X is big.
This precludes using 3D elements in details ... since they can't be used in the Detail windows. (I.e., our old conversation about the Detail window and MSA Detailer - where the MSA 'trick' for drawing sheathing is to use a wall.) Since 3D elements are ignored during a merge/copy/hotlink into a Detail window, it then becomes important that the original details in the master PLN file be done in Detail windows as well to avoid losing geometry due to forgetting to explode 3D elements were they to have been drawn in a story.
Thoughts?
Karl
