Orientation in View Map
mukster
I want to orient one of my plan on view map, but It also change orientation globally others plans, not just the one I want, then I do (redefine with current window setting)it still change all other plans, I tried to check and uncheck the (ignore zoom and rotation when opening this view box) still have the same problem
1 REPLY 1
You will need multiple views of the plan in the view map, so you can adjust each one as you want it.
Then you place each of those vies on the layouts as drawings as you need them.
