Orientation of Dimension Texts differs from model and Layout
Hi Guys,
I have used the Rotate Orientation function to rotate a floor plan 90 degrees.
I then dimensioned the drawing.
However when I bring the drawing into a layout, the orientation of the vertical dimensions rotates 180 degrees.
I have been able to correct text that gave me the same issue but not the dimension text.
Hope someone can help.
Thanks
Tim
1 REPLY 1
Eduardo Rolon
You have to update the Zoom Settings on the saved View (select Use Current) after Rotating the View and this will save your drawing rotation and the Dims.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
