‎2016-05-19
03:46 PM
‎2023-05-19
11:55 PM
Gordana Radonic
‎2016-05-19 04:47 PM
‎2016-05-19 05:07 PM
arqrivas wrote:Thanks for the reply. Will look forward to the new version. Until then, what would be a good workaround? All I can think of is to select all of the objects and manually change the surface each time I want to display them differently in a diagram....and then change them for renderings/walkthroughs. Any ideas? Thanks.
Hello, right now this is a task that will need a workaround to be achieve, but the new version (20) that is coming out the next month is going to have the graphics override, which will let you do that easily.
BTW please add your signature with the AC version you are using to receive more accurate and better help.
‎2016-05-19 05:18 PM
‎2016-05-19 07:08 PM
arqrivas wrote:I appreciate the feedback, thanks.
That is a solution, also it will depend, on the design process, but you can duplicate those things you want to change material and save them in a different layer and then having them show in a specific view. Or using the renovation filters and assign the elements to different filter.
