Oversized sheets when publishing
I've done a search but can't find anything relating to this problem:
When I publish to .pdf everything goes perfectly, but if I publish to anything else (jpeg, tif, psd etc.) the images that are output have a large white border, as if the page setup is set wrongly. It doesn't match any standard paper sizes that I use, and I can't see what I'm doing wrong...
Anybody got any suggestions?
Thanks in advance
3 Replies 3
I know it looks fine, but if you look at the size of the box that shows when you select the image you'll see its actual size... the white background is covering up the problem
Djordje
Convert your published PDFs to the bitmaps.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
that's what I've had to do.
But it's a presentation made up of over 50 drawings… so it's really very annoying.
