Overview of the relationship between Model Views, Graphic Overrides, etc. I lost my wall fills
svpribyl
In past projects, I had some settings that would make the cut walls' fill solid black for presentation views. I thought it was specified in Graphic Overrides (Make cut walls black), but that is not working any more. I have a renovation filter set up for new walls to be solid, but that isn't doing it either. Now there are even more complications with the use of Design Options. Has someone explained the interrelationship between all these features somewhere? Apparently, I'm not grasping the best method of handling all these "moving parts".
Thank you
Operating system used: Mac Intel-based Ventura 13.6.3
Steve Pribyl
MAC OS Sequoia 15.5
ArchiCAD 28
svpribyl
In addition are the complications of the Renovation Filter, which works with Graphic Overrides. I know, I know... these are all opportunities, not problems!
Steve Pribyl
MAC OS Sequoia 15.5
ArchiCAD 28
Sounds like it may be a conflict between the graphic override and the renovation filter, as they are often interconnected and can work together. Can you provide screenshots of your plan view, as well as the renovation filter and graphic override menus with the current settings that are applied?
Andrew Arkell
AC 18-27 USA 5030
HP Z6 G4 Workstation | Intel(R) Xeon(R) Gold 6226R CPU @ 2.90GHz | Windows 11
Setup info provided by author
