2004-01-08
04:34 AM
2025-01-29
05:27 PM
Aruzhan Ilaikova
2004-01-16 01:10 AM
2004-01-16 03:26 AM
Adalbert wrote:I dont know it is that bad since it was only the plan views that inherited the file name. Since the PLN method of saving doesnt create a folder with files in it, the unique name is not important.
In pre 8 by giving the pln a unique name (i.e. 0386,pln) all pmk’s inherited thos unique name… Now it takes a lot of typing. Thank you GS.
2004-01-16 05:07 PM
2004-01-16 05:48 PM
Adalbert wrote:Linking will work; there is no loss of time if you compare direct linking and updating the LBK compared to PMK publishing. Plus, you are rid of the file extension problem.
But I can’t abandon using PMK because I an afraid of:
- large projects may no work with direct PLN linking
- loosing file structure if moving from one drive to another
2004-01-16 08:12 PM
2004-01-17 12:52 AM
2004-01-17 01:31 AM
Djordje wrote:I have tried the direct linking and I find it slower than PMK publishing. I think I have a good hardware (although it isn't the ultimate computer in the world). Publishing PMKs I am able to update only a drawing at a time, while with direct linking I need to update the whole project.
You are, however, in the need of proper hardware for the project size.
2004-01-17 03:46 AM
Miquel wrote:That's not true. You can update as many or as few as you want and when you want--or none. You have complete control in the Drawing Usage window of the Navigator.
2004-01-17 05:45 PM
2004-01-17 08:29 PM
