‎2005-02-11
01:12 AM
‎2025-02-10
04:06 PM
Aruzhan Ilaikova
‎2005-02-11 01:21 AM
Steve wrote:With the fill tool draw a polygon the shape you would like the window to be.
Is there a way, when importing a AC project into Plotmaker to shape the drawing "window" in shapes other than a square or rectangle?? What if the room I am wanting to show is triangular, is there a way for the window to be triangular??
‎2005-02-11 01:30 AM
Steve wrote:yes - right-click on the drawing in question and go to "Drawing Settings...". you should see a setting in there somewhere for changing the drawing setting from a rectangle to a ploygon. once you've set it to 'polygon' you can edit the drawing boundary as you would any polygon in archiCAD: dragging nodes around and clicking an edge to create new nodes . . .
‎2005-02-11 01:32 AM
woodster wrote:oooh! that's a good one - i've never done it that way before . . .
Select the fill and the drawing.
Choose Edit/Set Polygon as Drawing Frame.
‎2005-02-11 01:44 AM
~/archiben wrote:It's the way we did it back in the olden days
‎2005-02-11 05:15 AM
‎2005-02-11 06:32 PM
‎2005-02-11 07:13 PM
Steve wrote:
Hey, by the way Woodie, did you teach ArchiCamp in Oakland Ca. a few years ago? If so, we attended and it was great - thanks!
‎2005-02-11 07:29 PM
woodster wrote:Woody,Steve wrote:With the fill tool draw a polygon the shape you would like the window to be.
Woody
