PLOTMAKER windows
Plotmaker 3.1.0.v1
Is there a way, when importing a AC project into Plotmaker to shape the drawing "window" in shapes other than a square or rectangle?? What if the room I am wanting to show is triangular, is there a way for the window to be triangular??
TIA!
Steve Ericsson
Olympia, Washington
8 Replies 8
With the fill tool draw a polygon the shape you would like the window to be.
Select the fill and the drawing.
Choose Edit/Set Polygon as Drawing Frame.
Woody
__archiben
yes - right-click on the drawing in question and go to "Drawing Settings...". you should see a setting in there somewhere for changing the drawing setting from a rectangle to a ploygon. once you've set it to 'polygon' you can edit the drawing boundary as you would any polygon in archiCAD: dragging nodes around and clicking an edge to create new nodes . . .
HTH
~/archiben
b e n _ f r o s t
__archiben
oooh! that's a good one - i've never done it that way before . . .
cheers
~/archiben
b e n _ f r o s t
It's the way we did it back in the olden days
I never did it your way. In Plotmaker 3 one had more freedom to develop the shape my way. In PlotMaker 9 you get the full capability to edit polygons as you get in ArchiCAD...
I'm switching to your way!
Aussie John
i've been using plotmaker since version 2(i think) or 3 and never noticed that option of setting polygon to frame
Cheers John
[/size]
Ben, that is AWSOME!! That is exactly what I was looking for!!! Woodie, great idea, unfortunately I like Ben's much better!
Thanks, fellas! Hey, by the way Woodie, did you teach ArchiCamp in Oakland Ca. a few years ago? If so, we attended and it was great - thanks!
I did... and we are in the midst of putting ArchiCAMP back on the map! Stay tuned!
Woody
Ben Odonnell
Woody
Woody,
What other plotmaker tips have got up you sleeve ?
I would really like to hear what your plans are for the ArchiCAMP as well. Could be a concept we could use here in Sweden.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
