2006-02-07 06:18 PM - last edited on 2023-05-26 02:36 AM by Gordana Radonic
2006-02-07 06:40 PM
2006-02-07 07:49 PM
2006-02-07 08:02 PM
andyro wrote:Archicad believes that all your PMKs
Yes, but I usually publish in groups ' selected items only' say, for the A3 series, and then the A4 series, etc. Reason being we have different PMK's coming from different PLNs (details, suites, landscape, etc. files)
If this doesn't happen when publishing real folder structure, I can try this and then cut-paste files into where they should be:
AHA! You're right. Publishing real folder structure (to my desktop rather than to the target folder on the server) doesn't append _2.
Where is the instruction being given/what cache is telling AC to write _2???
How can we disable this so we get proper overwriting of files?
A
2006-02-07 08:27 PM
2006-02-07 09:12 PM
andyro wrote:There is no cache that's tipping off Archicad. There is another view defined with the same name somewhere in the same viewset.
So you have separate PMK folders for all your various PLN sources, with Landscape, Plans A2, A3, and details, etc?
We can organize it either way, but The _2 behaviour seems sporadic.
I routinely republish 'selected' only using flat file structure and I get no _2 appended. Then other times the _2 is appended - that is what is troubling me.
The mystery for me is when I DELETE the entire contents of the target folder, clear all caches, and the _2 is written nevertheless.
The rationale for the _2 is clear enough, but what cache is tipping AC off to even write the _2? This is a big project and is already set up. I would rather just purge the cache in question and proceed as we have.....at this point...
Thanks,
A
2006-02-07 09:55 PM
