Peculiar Show As Trace Reference problem
Hi All.
Peculiar Problem.
When I create a new independent worksheet and attach an Xref It appears as it should in the worksheet. However, when I select for example 0. Ground floor and try to show the Xref as a trace it does not appear.
Weirdly when I go to trace & reference and hit the 'switch reference with Active' the xref appears for a split second before disappearing.
I am using ArchiCAD 20 EDU, but still also have ArchiCAD 19 EDU on my machine, when I try exactly the same procedure in ArchiCAD 19 no problem.
I want to stick with ArchiCAD 20, does anyone have a suggestion on something I need to do in ArchiCAD 20? I have tried re-installing it, and still have the same problem. Everything else works fine.
Apologies, I posted this in the new user section earlier by mistake.
1 REPLY 1
I worked it out, it was simply the imported drawing layers where switched off.
Sorry to waste anyones time
