2 weeks ago - last edited 2 weeks ago by Laszlo Nagy
Hi to all,
Do you know how can I delete a penset that is probably referenced somewhere and hence can't be removed because of it?
Many thanks!
Solved! Go to Solution.
2 weeks ago
You can try deleting it from the attribute manager -
Options - element attributes - attribute manager
Pensets, and you should have the option to delete. Then go to changes, apply all and that should be it.
2 weeks ago
2 weeks ago
One more thing: If the pen set being used in the project file, you will be given the option to replace it with another, existing, pen set.
