Phantom Label
Ciaran French
Beginner
Hi all,
I have a label in plan that has disappeared in my 3D environment but is still appearing in layouts.
Have tried isolating its layer, looking on all other layers & stories, re-linking the drawing, deleting & recreating the layout + checking it isn't a reservation filter issue but to no avail.
Wondering if this is an obvious fix that I'm overlooking or an uncommon glitch someone has previously resolved.
Thanks in advance!
Miha_M
Your "reservation filter" is probably the renovation filter. If it's not, try to change these settings.
Is / was it an associated element label? If that associated element is hidden, than the label gets hidden as well if the checkbox in the label settings is ticked:
Could it be a Display Order issue?
If you've deleted and re-created the layout it should not be a drawing update problem.
Could it be a different pen-set in your layout drawing, which makes the label invisible (white)?
There were some problems (bugs) with the label tool in archicad 24-25, maybe your problem is part of those bugs?
Archicad 24 - issues with label tool between view ... - Graphisoft Community
| Archicad 4.55 - 27
| HP Z840 | 2Ă— E5-2643 v4 | 64 GB RAM | Quadro M5000 | Windows 10 Pro x64
4 REPLIES 4
If it is not layers, maybe it is renovation status?
Open the source view and ensure the renovation filter is set to one that shows alls and doesn't hide anything.
Hi Barry - thanks for the response
Didn't think of this but unfortunately no luck on that either
Miha_M
| Archicad 4.55 - 27
Ciaran French
Beginner
It was an issue with the associated element - just deleted and re-modelled and it's working fine 🙂 Thanks again!
