Photorendering not showing surface image...
Llian
Here are my settings and not sure what I am missing...
Photorendering is not showing the wallpaper that is showing on the 3D...
Please help...thank you
undefined
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC28 USA | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
1 REPLY 1
You are probably rendering with the Cinerender engine.
The 3D window in Archicad displays the Hardware Acceleration (was known as OpenGL engine before).
If you look in the Surface settings you can make settings for Internal engine (was known as Vectorial engine). Hardware Acceleration engine (same settings as Internal engine) and also Cinerender engine.
The Cinerender settings can be completely different from the other settings.
So I would say you have a wallpaper texture in Hardware/internal but not Cinerender.
If you open the Cinerender settings, yo will see a button to "match settings'.
You can match the Cinerender settings from the Hardware settings (not this will only copy across the very simple settings of the Hardware/Internal engine - discarding all of the advanced settings you can make in Cinerender.
Or you can match the Hardware settings from Cinerender settings - this will only copy across the basic settings needed.
You can manually change the Cinerender settings for much more advanced control.
Changing settings in one engine will not change settings in the other.
You must do each manually or use the match settings method.
