Placing drawings in a layout, updating layers not updating
4hotshoes
Being new at this, there must be an easy explanation. After placing a floor plan on a sheet, I notice that some layers are not showing while others I don't want are showing. I select the inserted drawing and modify the layer setting then right click to update. But nothing is shown as changed. What is the proper way to do this?
Todd
Todd Oeftger
AC27 Mac MacBook Pro 15", 2019, 2.3 GHz i9, 32GB, Radeon Pro 560X 4GB, 500GB SSD, 32" Samsung Display (2560x1440)
1 REPLY 1
Robby
It sounds like you are attempting to place the floor plan from the project map to a sheet in Layout.
You should be working in the View Map area and you should place your drawing in Layout from the View Map not from the Project Map.
If this is confusing take a look at the Navigator- you will see 4 areas: Project Map - View Map - Layout Book - Publisher Sets. Views of a story with different combinations of layers can only be set and fixed into a "view" in the view map.
Rob Marelli
AC 27_5030
MacBook Pro (2023) M3 Max -48 Gb RAM - Sequoia 15.0
