2012-06-14
07:32 PM
2023-05-30
03:13 PM
Rubia Torres
2012-06-14 07:40 PM
2012-06-15 02:20 AM
2012-06-15 03:35 AM
gcrabtre6 wrote:Fix this by changing the skin priorities within the Composite - higher priority overrides lower one, so have, say, 12 for your core and 8 for your finish. Try reading THIS THREAD for more detail.
Karl,
thanks for your help! I kind of have it figured out. Problem now is, and this was an issue before with a composite wall, the "finish" shows up between 2 walls instead of the "core" elements meeting?
gcrabtre6 wrote:Offset the reference line by the thickness of the finish in the wall settings. (Image below)
Also, one other question? Is there a way to make the (construction method -left, right, center) node/grip allign with the "core" as opposed to the outside finish material?
2012-06-15 04:50 AM
2012-06-15 05:16 AM
2012-06-15 04:22 PM
2012-06-16 05:54 AM
2012-06-18 05:00 AM
