PlotMaker Publisher Fails
In PlotMaker's Publisher I have a couple of layouts that will not write to DWG even all the rest (eleven) layouts do fine. PlotMaker reports,
"Publishing of the item failed because PlotMaker was unable to generate it."
I have restarted, opened the file in ArchiCAD, re-saved it and then re-linked the files into the layout but still not luck.
It DOES publish in ArchiCAD, but then I don't get my whole sheet layout with Title Block etc.
Any ideas?
Thank you.
10 REPLIES 10
Aussie John
It might have been big but it worked (kind of):shock:
see http://archicad-talk.graphisoft.com/viewtopic.php?p=10238
for an update on the large file problem
Cheers John
[/size]
