maurotrotta
Publishing in DWG failing randomly
I have random errors while publishing documents in DWG format. Sometimes half of the files publish correctly, sometimes I just change the names because they might be too long but some other times it doesn´t work. I try different locations whewre to publish the files to see if it is a problem with the destination of my files, but it make no difference. I am lost about what can be causing this. If someone have any tip I will be tahnkfull.
In the publishing list, there will be a little yellow triangle next to any that fail.
Double click the triangle and see what it tells you.
Maybe that will help, maybe it won't.
