ā2006-03-17
09:47 PM
ā2023-05-30
10:09 AM
Rubia Torres
ā2006-03-18 12:57 AM
ā2006-03-18 05:36 PM
ā2006-03-18 07:15 PM
Matthew wrote:Nope. We let PlotMaker do everything. The first time you import something it's named correctly. The next time you open PlotMaker the name has changed. You may be right about identical PMKs though -- in the process of creating the PMKs in the background, PlotMaker might be changing the names for carity's sake. But if that is so, why does it work properly the first time you import, and every time you update?
Are you using PMKs?
ā2006-03-18 10:03 PM
Jay wrote:.... and people wonder why I never trusted the "Title Types" to name drawings....Matthew wrote:Nope. We let PlotMaker do everything. The first time you import something it's named correctly. The next time you open PlotMaker the name has changed. You may be right about identical PMKs though -- in the process of creating the PMKs in the background, PlotMaker might be changing the names for carity's sake. But if that is so, why does it work properly the first time you import, and every time you update?
Are you using PMKs?
This isn't the only project that has this behavior, most of our projects have this problem at one time or another.
ā2006-03-19 05:13 AM
Jay wrote:Regardless of PlotMaker, are you sure that the details should have identical names? Sounds like a good disaster recipe to me?
Is there any way to get PlotMaker to stop renaming the details? This has wasted a day's worth of man-hours just on this one project -- and I know it is happening on others, too. I'm not sure why you would want PM to rename details in the first place.
ā2006-03-20 05:35 PM
Djordje wrote:
...are you sure that the details should have identical names? Sounds like a good disaster recipe to me?
ā2006-03-20 05:50 PM
I have tried to get people to use names like "WALL SECTION @ RM# 105", but for some reason they're still in love with "WALL SECTION".
My million dollar idea is to create a mouse with a built-in tazer that will zap them when they do something stupid. Half the office would be unconscious for the first week.
