OK I'm late on this, but...
I now realise that John has the same problem as I've had several times. We like the looks of the shaded 3D view, made with the rendering engine set to Internal - but not "photorendered" or OpenGLed.
This view, with its line-emphasised edges and flat-shaded surfaces, has a not-too-real but real-enough ruler-drawn-perspective-like quality which is very suitable for certain presentations, when you want a level of abstraction that leaves just enough for the client's imagination to fill in. It's also easy and fast to create, and fairly easo to control if you've set your materials aned colors right.
It's not always easy to preserve this quality in presentations, when for example Plotmaker won't accept it completely, as John pointed out.
What I've done is to save/print the image to a pdf, and then make the presentation complete in Indesign, which is a bit above Plotmaker as a layout tool. You lose however Plotmaker's direct links to the AC model. You'll have to save out new pdfs and manually update all links in the presentation each time you change something in the AC model.
The pdf is losslessly scalable, which is a good thing when you don't know on what equipment it will be viewed or printed.
But there are other issues. The bit-mapped transparency rendering mentioned above is one. Also, Archicad renders the whole model (all visible layers/stories) when creating the 3D view this way, beginning with the surface farthest from the eyepoint, regardless of wether this surface is really visible from the eyepoint or not. The pdfs become huge containing layers upon layers of colored polygons covering each other, where most of them make no tribute to the final rendering at all, and each time you take a look or print it this layered rendering process will repeat itself. It's heavy processing each time, and some printers, especially those who have to little memory, or bad emulated Postsccript, will choke and refuse to output. (Some clients don't appreciate that)
(If you want to see it in detail, open the pdf in Acrobat Reader on an old, slow machine - with a properly made view, it looks like the model building is erecting itself before your eyes, and some years ago, we used this effect as a primitive animation).
One would like the pdf-save mechanism to just preserve the visible surfaces, but that (extremely slow) feature was removed some versions ago, I think.
One workaround is to open the pdf in Photoshop and make it a bitmap to your specifications there. That should take care of the resolution issue. Then save as a jpg and import in Plotmaker.
Another one is to photorender your view to an epix file and then tweak it in Piranesi, which can get you back to the pencil-drawn look. Fine, but it's not the same. And it requires full control of resolution issues if you don't want to risk jagged lines at final output.
