Stress Co_
Plotmaker in a bad accident
Help!
Plotmaker crashes each and everytime I try to open a Layout Book (the one I NEED to print NOW). I get the attached message right before the eventual Bug Report. Same story with the backup copy. Worked fine yesterday and I've not chaged the location of the .PLN (which I am able to open)
Putting the STRESS in Stress Co.
Any Ideas?
Marc Corney, Architect
Red Canoe Architecture, P. A.
5 Replies 5
Aussie John
Can you open the default file? or other files? can you open file on another computer? or user account? are you working across a network?
You may have a corrupt font. or you may have to move your preferences out of your user library (that way you can put your worksapce backin later)
Cheers John
[/size]
Stress Co_
John, thanks for your response
Yes, no problem
Aussie wrote:
or other files?
Yes, I can open other layout books
I only have the one
Aussie wrote:
or user account?
It's just me.
No.
How do I trouble shoot to check?
Aussie John
Make yourself a new user in accounts in system prefs. Try opening the file while logged into it. If it still doesnt work that will tell you that there is most likely a problem with the file rather than andything in the system (ie fonts). Before you do that move the graphisoft prefs file out off user> library>preferences and see if that fixes it.
Cheers John
[/size]
Aussie John
Also try a new plotmaker file and import the old into the new. You might get lucky with that
Cheers John
[/size]
Stress Co_
Gd'day John:
I did just that and was able to read and print the book (well, almost all of it). I narrowed the problem down to one page in the layout book. It was one that I "broke the Link" to (not to be confused with ArchiLink, but he's probally broke in Tahiti ) Loading that single sheet causes PM to crash. Not sure why. I get the same error message.
Thanks and Cheers,
Marc
