Plots are clipped H E L P !! Plotmaker 3.1
Plotter has been serviced and checks out by HP, and set to plot on "D" architectural. Master is Architectural "D" and Layout is set to "D" size. I have brought in the margins @ 2" from top and bottom and 4" from end to end. When I plot the image is partial and at the bottom right corner of the page. I also have adjusted the drawing to be centered in the Master "Settings" and I still get clipped plots. I have removed the Master borders and text areas and still the same. Can and one Please Help?
5 REPLIES 5
Could you post the file?
If it is too large, you may upload it to an ftp server and give us its web address so we can donwload it and look at it.
Thank you Lazlo,
Now can you describe how to up load to an ftp server and what file (s) you need to see......I'm new at this.
I know there are many placed where you can get free web storage.
If you search for 'free web storage' or similar, you can get to one of these sites. Then you will have to register to be able to upload files.
The site will tell you how to do it.
Then when you have the exact web address ofthe file, you can send us the address.
Thank you Laszlo,
I have figured out the problem. I had to fool Plotmaker Into thinking the orientation was Portrait and sheet in Landscape........all is well in Alaska today !!
OK, that's great
