Plotting scales - need some help.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2012-05-20
12:27 PM
2025-02-07
02:06 PM
Aruzhan Ilaikova
ps. When I started the plan I didn't select the scale that I wanted to work on, it was by default 1:100. Can anyone help me out?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-05-20 03:01 PM
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-05-20 05:18 PM
Did you checked DWG/DXF Translator settings?
You have to set proper drawing units for DWG export.
Check it in DWG translator setting box.
Probably this will help you.
Regards,
Ratna
Ram - 16.0 GB
System - Windows 10 Ultimate, 64 bit
NVEDIA GForce 8400GS
Archicad 9..., 24
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-05-20 11:17 PM
Click where it says 1:100 at the bottom of the Plan view window, a dialogue will appear, change to 1:50.
Save the view in the View Map, or if you have an existing view go to it's settings and click on the "Get current window's settings" button.
Place this view (from the View Map) on a Layout (which you should have a Title block Master assigned to, if you want a title).
Print.
Rinse and repeat.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-05-21 01:15 AM
s2art wrote:Dang, I knew forgot something
Rinse and repeat.
Mac OSX 10.11.1
AC5-18
Onuma System
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-05-21 07:13 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-05-21 11:33 AM
Mac OSX 10.11.1
AC5-18
Onuma System
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-05-22 03:38 AM
This will create a layout that will be identical in size, and a viewport identical in scale to that in ArchiCAD.
bikerutzu wrote:
Basically I saved the file in a dwg format so that my colleague can print it...
Also, if the only purpose for sending the dwg file to your colleague is to print your drawing, then consider using a PDF file instead. This will be a lot simpler to deal with and prints exactly the same as it is displayed in ArchiCAD on any machine. There are too many variables when saving to dwg that can affect how it prints!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-05-22 05:44 PM
Peter wrote:... such as your Autocad units in the translator. Don't know how it works in feet and inches, but you get different results if you use 1 unit = 1mm than if you use 1 unit = 1 metre.
So maybe you have the autocad units set to feet instead of inches or something like that.
