Plotting with an HP Design Jet 500
I can't get my plotter to print on a large scale. I can only print on 8.5"-11"
parameters. I need help on getting my plotter to print on 24" x 36"
8 Replies 8
The HP Designjet 500 series is treated as a plotter, not a printer by the ArchiCAD built in drivers. If you choose File>Plot Setup you should be able to specify all paper sizes upto A0 metric or US size 30" x 40".
BTW it helps if you include your computer spec, ArchiCAD version and Operating system in your signature - change it in your profile.
i have not been able to get my hp DJ500 to "plot" to a 30" x 40" Oversized E1 sheet. But, if i "print" to the hpdj500 i can plot/print to the E1 oversized sheet. in the AC10 sheet size menu for plotting to the dj500, the 30"x40" E1 sheet size option is not provided. try "printing" to it.
Sam Wheatley
I have a hp 500 design jet plotter, and when I first purchased it didn't come with an HPGL2 card for plotting. I bought and installed the card and plotting has been fine ever sense. If I remember the cost was about $250
ArchiCad 26 US
IMac Pro
iMac 3.2 GHz Intel Core i5 16 GB
NIVIDIA GeForce GT 755M 1024 MB
Jere
We have an HP DesignJet 500 and use only the 'print' function, never the plot and things work great. No issues at all with paper sizes.
ArchiCAD 26; Windows 11; Intel i7-10700KF; 64GB RAM, GeForce GTX 3060
We have found that we sometimes get a similar problem.
The printer or plotter if you want can not find the correct paper size. However if we go into page setup>properties (of the printer) we can select the correct paper sizes, OK to exit both properties and page setup.
The next time we open page setup or print>page setup the full list of paper sizes are available.
This does not effect all projects and occasionally needs fixing more than once on the same project.
I'm looking at changing my office over from PC tp Mac. It also happens to coincide with my old plotter dying. I'm looking at the HP500, but am not sure it will be compatible with the new Mac.
Any thoughts?
TomWaltz
Any thoughts?
Mac OS X is listed as being compatible, assuming this is the same model
http://h10010.www1.hp.com/wwpc/us/en/sm/WF06b/18972-18972-3328061-12600-3328078-25301-377949-20994.h...
Tom Waltz
aahatimo
Any thoughts?
we plot & print fine on mac platform w/ a 24" hp500 w/ jet direct card and hp gl2 card and 128 mb memory.
you may want to check out the hp t610 series. i believe they are the replacement series for the older hp500/800 s. twice the resolution,1200x2400, supposedly 3x faster, 300' paper rolls and new ink delivery technology.
http://h10010.www1.hp.com/wwpc/us/en/sm/WF06b/18972-18972-3328061-12600-3328078-3339415-3339417-3339...
they are not out yet, a friend of mine has one on order.
tim hanagan
aaha! design studio durango, co
27" retina 5k iMac 4ghz i7 os 10.13.6 m395x 4 mb, 32gb ram, 512 gb ssd ac 22 current
15" retina mbp 2.6ghz 1mb 16gb ac 22 current[/size]
